Outbuilding Regs October 2008 (my garage)
Posted: Thu May 21, 2009 10:44 pm
Building Garage at home, it is stand alone so not connected to house.
Been reading new outlines regarding PP and BC.
The build will be within 1 metre of neighbours boundary and the same applies to canal tow path outside my house (nice spot).
So the build will be between 15-30 sq metres, so I'm I right in thinking if the garage is not more than 2.5metres at highest point and built out of block and render with tiled/slated roof, no need for PP or BC to be informed. I will be installing electric but registered full scope sparky, so that's no problem. Not conservation area, national park or listed.
Garage will be set back from house.
My intention is to fit once pitched roof will about 12 degree fall on it to maximize height and other fall so no water settlement.
Does this fit in with regulations.
Thanks for all replies, especially if I've missed something.
Off to climb a mountain, so will be back to see you all once conquest has been claimed.
Hope you all have good Bank Holiday Weekend
KB
KB
