sewer manhole inside flat and building regs
Posted: Fri Jan 15, 2010 12:01 pm
Didn't know if should post in 'Bathrooms, drainage and waste plumbing' but as it is re building regs- here it is.
In the basement flat I live in, discovered the last manhole access before the main/public sewer was under the lino in the store cupboard inside my flat. I've had to deal with 2 blockages that needed to be cleared (not my fault- I know better then to put wet wipes etc down loo!) and it is a constant worry as I am the one who always has to deal with it if there is a blockage.
I thought that if a sewer manhole serves more then 1 property (4 flats go into this), that the sewer access has to be in an obvious and accessible space and if I am not here- how is the sewer manhole in my store cupboard inside my flat accessible?
Landlord says this conforms to building regs and to have it outside the flat is 'best practice' but not absolutely a 'must do'. The original plans showed it was to be moved outside the property so help with clarification please?
And have I got it right that building regs say a 'low level' access is required to the soil waste pipe (in my flat - serving 4 flats)? There is a boxed access point on the soil waste pipe that is 100cm above floor level- is that considered 'low level'? When the plumbers were here to clear the sewer trap blockage they said they wouldn't want to open it because depending on where the blockage was- it could flood my bathroom with sewage from above. Such fun.
Plumbers were also surprised as there is no access in the floor at the junction of the pipe leading from this main waste down pipe where it connects with the main pipe running into the sewer manhole. They were unable to get a camera around the sharp bend and said that it could be a snagging point for debris and cause a blockage. ?
Hope I've been clear as trying to understand and help with clarification of regs in appreciated.
