Removal of the Ground Floor Chimney Breast for Knock Through
Posted: Mon Feb 27, 2017 2:25 pm
by Cathalmf
Im looking to knock through the wall between the kitchen and the living room to create an open kitchen/living area.
There is a chimney in the ground floor as part of that partition wall.
The chimney is not attached to any of the outer walls of the house.
The chimney has previous been removed by the original owner from the first floor.
The chimney stack is still present on the roof
Either side of the chimney is just timber stud work.
There is an RSJ running from the front to back of the house about 1 meter to the left of the chimney so im assuming that this is holding the load and not the chimney stack.
How safe would it be to DIY the removal?
How much should it cost to get someone to do a professional job?
Re: Removal of the Ground Floor Chimney Breast for Knock Through
Posted: Mon Feb 27, 2017 5:34 pm
by welsh brickie
Before you do anything call a structural engineer for advice, I would not attempt this myself without consultation.
Also building control will have to be informed and any steels passed by the inspector
Posted: Tue Feb 28, 2017 11:19 am
by Cathalmf
Ill most likely get a builder to do it.
Ceiling was already secured by the previous owner when they removed the first floor chimney so no more steel should be required. Just removal of the chimney.
Im assuming chimney removal internally is permitted development. Cant find anything online to say otherwise.
