We have blocked up our external kitchen door and are now selling the house and need a late completion certificate but the council are being a nightmare. We have submitted a diagram showing we done 100mm concrete block with a 50mm clear cavity and 50mm insulation then 100mm concrete block. He now needs to know the type of insulation used and the thickness (he said the 50mm cavity and 50mm insulation isn't correct) it is standard construction wall. Can anybody tell me what should have been done and what insulation should be used?
