Create opening in load bearing wall at bottom of staircase
Posted: Fri Apr 15, 2022 10:13 am
by Rob7256a
Hi I am looking for some advice before contacting BC.
I am looking at adding a small side extension with access via an opening at the bottom of the staircase in the original building. There isn't enough room for the 400mm clearance required by BC between the bottom of the staircase and a new door. But can I create an opening the size of door way (with correct lintel) to allow access to the new extension without a door or have the door open into the extension away from the staircase?
Many thanks
Rob
Re: Create opening in load bearing wall at bottom of staircase
Posted: Wed May 04, 2022 3:11 pm
by GR1587
Rob7256a wrote:Hi I am looking for some advice before contacting BC.
Many thanks
Rob
Could you put a sliding door in on the extension side?
or a bi-fold door?
