Knocking through outbuildings... Do I need building regs?
Posted: Fri Jan 05, 2024 5:22 pm
by dss123
Hey all.
I have a brick outbuilding which is currently subdivided into 4 sheds. I would like to knock the brick walls out between 3 of the sheds to make one large space for a home gym. This space will end up about 25m sq. Will I need to obtain planning permission for this alteration? I'll be removing internal brick walls, adding steels, blocking up external doorways and laying a concrete floor. But it won't be used for sleeping / accommodation and I won't be altering the existing external footprint.
Duncan
Re: Knocking through outbuildings... Do I need building regs?
Posted: Sun Jan 07, 2024 11:07 pm
Hi labourer,
If it’s a detached building and you are not going to instal a bathroom and cooking facilities, probably not. You could always ask you local building control team but you are unlikely to get an answer unless you provide plans including a site plan.
Posted: Mon Jan 08, 2024 10:07 am
by dss123
Hi labourer,
Many thanks mate....
