Requirements for extending kitchen into existing porch area
Posted: Mon Jan 28, 2008 11:25 am
We would like to extend our kitchen into an area currently used as a porch/utility room. The porch is structurally part of the house so building mods are limited to new windows/doors and bricking-up a window, it was built as a porch extension filling in the original L shape space some 25 years ago. We moved into the house 3 months ago.
The work would go something like this:-
- New front door into end of hall replacing a full height hall window, no brickwork mods. (This would give access direct into house allowing for kitchen to extend in to current porch space)
- Replace existing flag shape front door that accesses porch area with standard window. (effectively becoming new end kitchen window)
- Remove existing internal door between porch and house and wall off.
- Brick up existing side porch window.
- Remove internal window from kitchen and knock out wall underneath to create one room.
Do we have to notify anyone about this work? I will have a FENSA window company to install the new door and window and use a local builder to do the walls etc. The electrics will be by a P certified electrician.
Thanks for your help..
