backed up itunes...
Help and advice on software, hardware, configuration and general computing issues and problems
chris_on_tour2002
backed up itunes...
by chris_on_tour2002 » Sun Jun 05, 2011 12:13 am
hi folks,
hope someone can help - i recently bought an external hard drive to back up my home computer. rather sensible i thought.
tried to back up my music library which was partly successful, though instead of copying my library to the hard drive i instead moved it all across.
my itunes now does not work as it cannot find the files, even when the external drive is connected and up and running. i can click on the files and play via media player but it's a royal pain.
for some reason i can't copy the files back onto my pc hard drive. no idea why!
HEEELP!!!!
by stoneyboy » Sun Jun 05, 2011 10:38 pm
chris_on_tour2002,
If the music files won't copy back directly try copying them onto a usb stick and move them back into the correct itunes library on your computer. file location will be something like itunes/itunes music/music.
chris_on_tour2002
by chris_on_tour2002 » Sat Jun 11, 2011 12:00 am
thanks stoneyboy, i will try that.
i've looked thru explorer and can't find the original file for itunes. do you think it would reappear if i uninstalled and reinstalled it?
by stoneyboy » Sat Jun 11, 2011 10:22 pm
chris_on_tour2002,
Don't uninstall and reinstall itunes, try copying your original itunes music folder back to the itunes music folder. Then try playing one of your tunes - you may have to redirect itunes to the file location.
chris_on_tour2002
by chris_on_tour2002 » Mon Jun 13, 2011 10:47 am
well it seems that when i tried to copy the music library to the external drive i moved them instead, including the folders which is why itunes couldn't find it. managed to copy the files back onto my computer but itunes still couldn't find them.
so i did as you said and told itunes to look in a different location! bleedin' obvious now innit?
had already reinstalled itunes, i do it fairly often as it seems to stop functioning properly once a few updates have been installed.
now works fine except that it now won't recognise my iphone! cuh, solve one problem, inherit another.
thanks for the advice stoney, at least i can listen to my music again!
It is currently Sat Dec 28, 2024 9:47 am
