Corner Panel Split and Opening on Conservatory
Posted: Mon Mar 24, 2014 8:33 pm
by brendon1703
We had our conservatory put up in 2008 and in the last year there has been a slightly gap appearing on the corner which is slowly getting bigger. The gap is on the lower corner panel which joins the side panel, the gap at the bottom is about 5mm. It looks like the side panel is coming away from the front panel.
I have tried pushing closed with no luck, but worried the gap will get bigger.
Many thanks
Brendon
Re: Corner Panel Split and Opening on Conservatory
Posted: Tue Mar 25, 2014 7:24 am
by welsh brickie
you can remove the plastic beads with a sharp flat paint scraper, then remove the panel and reposition, silicone in place then refit the beads
