Conservatory Ceiling/ soil pipe
Posted: Sat Dec 08, 2007 3:28 pm
by Martin Barkley
I have recently moved in to a new house with a conservatory on the back, the soil pipe is in the conservatory and has been nicely boxed in. I have just walked in to the conservatory and noticed water on the floor which is coming from the boxed unit, as this has not been seen before and it has been raining for most of the day i presume it is from the conservatory roof which as the soil pipe coming through. Ive been above and looked from the bathroom window but cant tell if the material used has withered or not. If so what material can i get to fix this problem and any ideas on how to do it. Would i need to remove the adjacent panel.
Posted: Sat Apr 12, 2008 9:59 am
by welsh brickie
your best bet is to check first where the water is getting in.I would remove
one of the panels in the roof nearest to the soil pipe as you can see better
carefull not to break polycarb or the roof bar plastic cover.At the bottom of each roof bar is a cap with a plastic button remove and unscrew.
The cover bar is clipped in so carefully use blunt screwdriver and tap with hammer to prise cover off .
there should be a weather slate installed its a square piece of aluminium
with a rubber sleeve to take the soil stack make sure its well sealed by using a watering can to soak the area .
If its only lead around the soil pipe you will need to install a weather slate .
