Lowering loft floor to get head height in loft
Posted: Thu Sep 18, 2008 3:29 pm
by albo
Hi! New boy here......I've been advised that it's possible to lower the existing loft floor in my house to give a reasonable head height to a proposed loft conversion I'm looking at doing.
This 1. sounds expensive and 2. extremely messy. This would I assume necessitate the lowering of the first floor ceiling...or am I being daft.
If this is the case are there any books/advice that can give me a few pointers before I engage the services of a Loft Conversion outfit or even an architect.
I'm not intending doing the work myself I just like to be armed with all the relevant info so I know what's going on.
Albo
Posted: Wed Oct 15, 2008 9:44 am
by toptips
hi,i done the same job for a friend,we first built new 7x2 ceilings in all the bedrooms and the landing about a foot lower than the existing.all the lighting was then fitted to the lower ceilings.
as it was a playroom only a velox window was fitted and all the old lath and plaster ceilings were passed through this and on to a tower to be removed,as you can imagine the dust was very bad to say the least but very little was leaked below.
the new 7x2 ceilings then became the loft floor,he was very lucky and got all the timber for £100 from a site that had overordered.
Posted: Wed Oct 22, 2008 5:21 pm
by albo
thanks toptips, i'll have a look at this and see how feasible it is.
loft height
Posted: Wed Nov 26, 2008 9:56 pm
by mdpmspitfire
could i suggest a dormer roof or a type of atrium to give you the additional height. both obviously need planning but an atrium looks fantastic, gives great light a view plus loads of ventilation if incorporated.
you could construct roof to match existing pitch of house.
mark
Posted: Thu Dec 11, 2008 8:17 am
by gaconsult
if you remove old ceiling joists and lower the ceiling be careful as the old ceiling joists act as a tie for the rafters to prevent roof spread.
Posted: Fri Jan 30, 2009 9:16 am
by TheDoctor5
