Converting a single brick outhouse but are internal walls loadbearing?
Posted: Sat Jun 13, 2020 11:30 pm
by Jon aharvey
I currently have a single brick outhouse attached to the side of my 1950s semi. It's roughly 12' x 12' and consists of 3 small rooms and a lobby. The roof is a re-enforced concrete slab. I'm looking at removing all internal walls to open it up and create a usable room. My question is are the internal walls likely to be load bearing? Atleast one neighbour has removed all walls without installing any RSJs. Does this sound feasible?
Re: Converting a single brick outhouse but are internal walls loadbearing?
Posted: Sun Jun 14, 2020 10:42 pm
Hi jonaharvey
Given the age of your property and the span involved it is likely that the walls are load bearing. Even if you got a structural surveyor to have a look I doubt they would give the ok to remove internal walls.
