GRAVEL DRIVEWAY SINKING
Posted: Thu Oct 04, 2007 5:26 am
by yogs1959
Just had a gravel/stone driveway done which is on a slope, cant use it as the car sinks into the stone and gets stuck, builder wont come back, the top stone seems to be too small and about 8 inches deep, running out of money to get another builder in, have been told if i get some quarry dust and then compact it that will make it solid, can anyone give me a cheap way to sort the problem i am in serious trouble as i now have to park the car on the road side, PLEASE HELP.
Posted: Fri Oct 05, 2007 8:21 pm
by LCL
yogs1959
Oh dear. Bit of an issue to sort that unfortunately to sort property will not be too cheap.
Firstly I would not advise loose gravel being laid on a slope. Best case scenario, you'll be raking it all back up the drive every weekend, otherwise you'll end up with it all at the bottom and dragging out into the road.
A drive should never have 8" of gravel, its hardly any wonder your car sinks, you'll have to get one of those little hovercraft things.
There will be various ways this can be resolved. My prefered solution would be to have a concrete base and roll the gravel into the top of the concrete while it is still wet. This will give the appearance of a gravel drive but will be solid to walk upon. You can then have a 2" deep gravel drive where it is level.
I can appreciate the quarry dust idea, similar to using sand I guess. You will effectively have a ballast driveway, but at 8" deep this will not last too long either.
Hope this helps
LCL
help at hand
Posted: Thu Jul 15, 2010 8:07 pm
by TheDoctor4
For up to 5 FREE quotes from trusted, vetted and insured tradesmen in your area visit the DIY Doctor Find a Tradesman page:
https://www.diydoctor.org.uk/find_tradesmen/
