Log cabin gravel foundations - Drainage question
Posted: Wed Feb 01, 2023 8:48 pm
I am planning on building a 12 x 8 foot log cabin and using a gravel base with timber surround to hold in the gravel.
There is a slight slope. The top of of the garden slopes down towards the bottom end. I am therefore going to dig this out and have a small retaining wooden wall which works out to be 2 feet in height (maximum) which will go down to ground level nearer the bottom of the garden.
So i plan on using wooden timbers for the surround and fill with gravel.
My question is in relation to drainage, as this is only going to be a small retaining wall is it at all necessary?
Some guides seem to indicate using French drain pipe outside the retaining wall at the top which makes sense. However, this isn't just a retaining wall it is also a surround for a log cabin. (finished gravel pit will be a rectangle). Do you think i should also require the same drainage system within the closure of the new foundation base, is that is required? I have drawings of my plans and would make more sense but can't see a way to post them on here.
Hoping the description above makes sense! Be grateful for thoughts and advice.
Thanks in advance!
Thanks in advance!
