Heat Proofing Plaster Walls
Posted: Wed Dec 05, 2007 12:45 pm
by amcdon4117
I have a pair of woodburners that are begining to damage (cracking plaster) the plaster walls (plaster on plasterboard) closeby. Can anyone advise on the best methods of replacing these surfaces (fitting flush with surrounding plasterwork) with a material that would be heat proof and paintable?
Vitcas Heatproof Plaster
Posted: Wed Nov 26, 2008 1:59 pm
by alexx
You can buy Vitcas Heat Resistant Plaster and Vitcas Heatproof Screed and other high quality Refractory Materials like Premium Fire Cement directly from manufacturer in Bristol or you can Google "vitcas.com" or "firecement.co.uk"
Posted: Wed Jan 28, 2009 10:33 am
by TheDoctor5
