-+- ?? Vertical DPC ?? -+-
Posted: Fri May 09, 2008 12:42 am
by Lee_Hewitt
Hello All,
I'm ready to start building my walls up from DPC but where the extension buts up to the existing building I need to know if I need to fit a vertical DPC to the existing wall in between the inner & outer leaf of where my new walls will be built. If I need this vertical DPC I then need to know how to fit it to the existing wall, i.e. do I cut a slot with a disk cutter and silicone it in?
As always, many thanks in advance,
Lee Hewitt.
vertical dpc
Posted: Fri May 09, 2008 9:16 pm
by welsh brickie
you do not need a vertical dpc from your existing property to new
extension but a fixed mechanical profile must be used to attach new
extension to existing building.
Posted: Sun May 11, 2008 9:18 pm
by Lee_Hewitt
Many thanks for this help. What is a fixed mechanical profile? Is this a 'aligator' wall tie strip?
Many thanks again,
Lee Hewitt.
mechanical fix
Posted: Mon May 12, 2008 9:21 am
by welsh brickie
yes you fix it to the wall using 10mm bolts there are various named
versions on the market crocodile being on of them.
Posted: Sat May 17, 2008 6:56 pm
by LCL
Lee_Hewitt
I think I understand your problem.
If you disk out two slots and remove the brickwork, therefore effectively running the cavity continuously between the new building and the extension, you do not requie a DPC.
Building control are likely to require this anyhow to avoid a cold bridge.
If your plan was to make a single disc cut in the brickwork (what is currentyl the external skin, but will become an internal wall) you will require a vertical DCP to prevent penetrating damp. This method is not to be advised as there will be a cold bridge issue.
Hope this helps
LCL
Posted: Thu Jan 22, 2009 10:07 am
by TheDoctor5
