Cutting a new doorway in a single brick wall
russellfl
by russellfl » Sun Jul 13, 2008 5:23 pm
Hi, can anyone tell me the process for cutting an internal doorway. Hallway to lounge?
The wall is a single block wall in a bungalow and doesn't support anything as it runs the same way as the roof joists. I presume I will need a lintel? even though there's only one block above where the new doorway will be.
Would you advise cutting the opening exaxtly to the size of the new door lining or to cut it bigger and put something like 100mm to 50mm timber in between to make sure it won't flex out of true?
Cheers!
Perry525
by Perry525 » Sun Jul 20, 2008 4:05 pm
Before cutting the hole, take into account the swing of the door and its best position. Decide on the line and fix battens on the wall to use as a guide, cut the hole larger than the frame size to allow for adjustment, remove the blocks starting at the ceiling, fit a wooden lintel to carry the load above the doorway.
TheDoctor5
by TheDoctor5 » Thu Jan 22, 2009 9:53 am
It is currently Thu Dec 05, 2024 2:14 am
