Hole through cavity wall.
AjayK46
by AjayK46 » Sun Mar 29, 2009 12:48 pm
I have just removed a sink from a bedroom which is no longer required. What is the best / easiest way to fill the hole where the waste pipe went through the cavity wall on both inside and outside ?
Thank you.
rosebery
by rosebery » Mon Mar 30, 2009 12:42 am
Mortar outside and inside. Flush with wall outside. Leave enough space inside to apply plaster.
HTH
AjayK46
by AjayK46 » Mon Mar 30, 2009 3:18 pm
Thanks very much. All done ok.
It is currently Fri Jan 10, 2025 4:50 am
