Close/bridge top of cavity walls? - New build
Posted: Fri Sep 25, 2009 1:19 am
Hi all,
We are having an extension/conservatory built. The builder has now left site after completing the brickwork construction and gone on holiday. In the next two weeks the conservatory wll be built. The exterior walls will be rendered, when the builder returns.
In the mean time he has left open the tops of the wall cavities, and the insulation is visible below. Not wanting to introduce water into the cavities. Should I close/bridge the cavity perhaps with self adhesive flashband, which could be removed if need be? Or should the cavity be left open or closed?
Many thanks.
Many thanks.
