bonding spots
Posted: Fri Apr 02, 2010 11:11 am
by stevemarsh1
we have just had living room replastered using plasterboard and plaster bonding we have then had it skimmed we have sized the walls with weak paste 1 coat of white emulsion then the colour we wanted which was matt however with these 2 coats on we are still getting bonding spots coming through any ideas thanks
Posted: Sat Apr 03, 2010 12:04 am
stevemarsh1,
"we are still getting bonding spots coming through" if you are referring to the dot and dab fixing areas then this may be because damp is penetrating through the plasterboard. This can either be because you did not allow enough time between fixing and painting or the boards have been fixed to an inherently damp wall.
Leave things until we get some drying weather and see if the problem persists.
Posted: Tue May 04, 2010 10:14 pm
by polishingpeanuts
I'll second that stonyboy!
