How to Seal and Clean Exlernal Brickwork
Posted: Mon May 31, 2010 11:38 am
by cerdyn
We have a victorian house, as a result of some damp we have had a small amount of repointing carried out to the external brickwork. Unfortunatelly some bricks have been 'smeared' with mortar - could someone tell us the best way to remove/clean this?
Also, we wondered what the best product would be to seal the external bickwork to help protect it?
Many thanks in advance for your help.
Regards - Steve
Posted: Wed Jun 02, 2010 11:24 am
by brithebuilder
For cleaning the mortar stains off the bricks the best thing is a proprietary mortar stain remover which is available from most diy stores or builders merchants. It's usually possible to dilute this by adding it to an equal quantity of water, the advantage of this being that the action is less agressive and wont damage your new pointing. As for sealing the brickwork, I personally don't reccomend this, especially with the solid brickwork your house is almost certaintly constructed in, as it traps any damp already in the structure. As long as the pointing is in good order and there are no leaking gutters causing water to run down the walls all should be fine.
Help from DIY Doctor!
Posted: Fri Jun 25, 2010 6:41 pm
by TheDoctor4
Let DIY Doctor help you to find quotes from vetted and trusted tradesman local to your area. Visit our Find a Tradesman page: https://www.diydoctor.org.uk/find_tradesmen/
