Wooden Lintel in a brick outhouse
Posted: Fri Aug 06, 2010 7:21 pm
by jagboy
I couldn't see anything relevant, but I have an old brick outhouse that I'm currently re-pointing. It's single course and single story and there's a wooden lintel about 3' above the ground that's at least 2m long. It can't possibly be doing anything structural, so would it be possible to replace the lintel with a brick course? I was planning to chisel out a section at a time to make sure that as I replace it the new brick course has a chance to harden - It's very old and I'd be worried about taking it all out at once even with strongboys - they're supposed to be good for 900mm span but is this true, even with ropey brickwork?
Thanks for looking!
Martin
Posted: Sat Aug 07, 2010 11:26 am
by collectors
Concrete Lintel Product Code: 244005 Size: 70 x 100 x 1800mm from wicks might do the trick for just over £10.00.
But it all depends on what its supporting.
Posted: Tue Mar 22, 2011 6:01 pm
by jagboy
A quick update: A builder suggested wedging the bricks temporarily with slate bits whilst the cement hardened. I did a couple of bricks at a time over the course of a few weeks and all seems good. This was done in the summer and there's no sign of movement :-)
