4inch blockwork wall
Posted: Mon Apr 11, 2011 1:13 am
by dan83
I am planning to build a 4 inch blockwork wall aprox 1.5high x 7m long in the back garden. I am wondering if and were if needed i would need to put a movement joint and also supports in the wall. the wall is not load bearing
block wall
Posted: Mon Apr 11, 2011 11:51 am
by welsh brickie
you need pillars at each end of the wall and where the expansion joint is in the middle of the wall at 3.5metres,So 4 pillars in total
Posted: Wed Jun 08, 2011 9:09 pm
by andy01
you could get away with three piers.
place the movement joint next to the central pier and use debonded wall ties at 225mm vertical centres
