Filling large and deep hole in a brick wall to hang curtain holders
Posted: Sat Jan 23, 2016 9:20 am
by Pino
Hi All,
I have a large hole 10 cm wide, 10 cm high and 5 cm deep in my brick wall and I would like to know what is the best way to fill it. Once it is filled I would like to be able to drill holes in it so that I can hang curtain holders.
Re: Filling large and deep hole in a brick wall to hang curtain holders
Posted: Sun Jan 24, 2016 7:19 pm
by welsh brickie
Mix a P.V.A solution and apply it on the area, then mix some dry wall adhesive and fill the holes, the mixture should be like thick cream, over fill the holes slightly and sand back when set 24hrs later
Posted: Sun Jan 24, 2016 10:37 pm
by Pino
Thanks but since the hole is quite deep if I fill only with wall adhesive would I be able to drill and hang curtain on the filled hole?
Posted: Sat Feb 20, 2016 9:10 pm
by welsh brickie
yes
Posted: Sun Feb 21, 2016 8:58 am
by Pino
Could you please let me know what wall adhesive should I use?
Posted: Wed Mar 23, 2016 5:09 am
by melving.crane
Pino, I think you should use cement plaster on the deep holes. Make cement mixture liquid type and paste the liquid cement into the hole. Hopefully it'll be add nicely, so that you can later make hole to hang curtain holders.
Posted: Thu Mar 31, 2016 9:08 am
by Pino
Hi Melving,
could you advise what product to use which I can easily find in one of the DIY stores?
Emanuele
