welsh brickie wrote:I normally drill it and insert some rebar or screw rod and epoxy resin to set it in position, then drill the pillar and bed it into place
Is there an alternative method ? and is there a trade name for the RESIN. If a rod is used does the cap still need to be bedded in mortar ?
