Pier cap fixing fir setting heavy port cap
Posted: Fri Jul 29, 2016 7:32 pm
by bladebod
Hi I need advice on setting a heavy port cap in place ie what do I fix it with ?
Re: Pier cap fixing fir setting heavy port cap
Posted: Sat Jul 30, 2016 5:36 pm
by welsh brickie
I normally drill it and insert some rebar or screw rod and epoxy resin to set it in position, then drill the pillar and bed it into place
Posted: Tue Aug 02, 2016 2:16 pm
by bladebod
welsh brickie wrote:I normally drill it and insert some rebar or screw rod and epoxy resin to set it in position, then drill the pillar and bed it into place
Is there an alternative method ? and is there a trade name for the RESIN. If a rod is used does the cap still need to be bedded in mortar ?
Posted: Wed Aug 03, 2016 5:48 pm
by welsh brickie
the resin you can buy from screwfix, and yes bed it on sand and cement
