Lime mortar with modern materials
Posted: Tue Feb 15, 2022 11:52 pm
I'm looking to build some piers alongside a bungaroosh wall to add support. I'm thinking about a single concrete block laid flat and tied to wall where possible with stainless frame ties, then wrapping the blocks with brickwork.
My question is: Would it be ok to use sand and cement for the new work as it is its own structure, or do I need to be using hydraulic lime? If so, can you use lime with concrete blocks?
I can't seem to find any info about this online, other than using a lime render on concrete blocks.
