Underground drain pipes not sealed off
Posted: Sun Nov 11, 2007 10:06 pm
by bornlivelife
HI
This is the last post on this now, as I think i finally know the problem
some drains were moved outside my semi to enable an extension to be built
the drains were not sealed and thre are cavities under the extension which have rats in them, somehow the area has opeened up such that they can get into an internal wall in the house
i can either put conrete in the internal wall, or can pump it up a disused branch of a drain
which is best or what should i do , please !!
Posted: Sun Nov 11, 2007 10:18 pm
by thedoctor
If there is an unused branch of a drain it can be blocked certainly. You can buy stoppers which are usually used for blocking drains while they are tested for leaks but they can be used for this also. They screw into the drain and can be unscrewed again if ever they need to be but they can also stop in permanantly. You can buy them from any builders merchants.
Posted: Sun Nov 11, 2007 10:38 pm
by bornlivelife
yes thanks
i have one already in 1 branch
problem is there is a disused cavity deeper inside
so wondering if i could pump conrete deepinside in an attmept to fill it
dont want to pump too far though as it will go down another disused branch from disued manhole under extension whichwill eventually lead back to a used main sewer
if i can pump maybe 2 metres down, then i should be ok...
id also like to pump down through the cavity wall untill the 2 pumped laods meet, but i think u said i cant pump into an internal wall that was once external
Posted: Sun Nov 11, 2007 11:11 pm
by bornlivelife
one of the unused pipes i have blocked yes
problem is the other one is not accesible (under extension)
however if i pump conret into the first one it should eventually flow into the second one, as long as i dont pump too far which will blcok the whole thing !
u reckon i can just pump in maybe 3 metres worth of pipe length?
Posted: Thu Jan 22, 2009 10:28 am
by TheDoctor5
