Vertical decking board
Ask questions and find answers on all your decking problems and issues
g0ggs
by g0ggs » Fri Sep 11, 2020 11:05 am
Hello
We have a gap between the ground and the decking structure which is too large to be covered if the decking board is placed vertical .
Has anyone used small sections of decking board cut to size to cover a large gap rather than have a long board covering the side ?
Gordon
Re: Vertical decking board
by stoneyboy » Sat Sep 12, 2020 10:28 pm
Hi g0ggs
Sorry there is not enough detail with your question, can you post a photo?
g0ggs
by g0ggs » Sun Sep 13, 2020 7:52 am
Hi Stoneyboy
It’s the side panel I’m talking about , if I put a decking board along it there will be a gap and I’ll see the bricks under but if I chop up the decking board into small sections and put them facing downward I could get more brick hidden at the bottom.
by stoneyboy » Sun Sep 13, 2020 2:40 pm
Hi g0ggs
You could do vertical slats but end grain will then be in the ground and short lengths of decking do not season well. Better to cut boards along the length and fit two narrower pieces horizontally.
g0ggs
by g0ggs » Mon Sep 14, 2020 9:14 am
Ah thanks for confirming that , was one of my concerns!
All the best
G
It is currently Sun Dec 22, 2024 5:36 am
