Decking questions for new project please help
Posted: Mon Mar 11, 2024 7:06 pm
Hi I am building some decking (with the help of my young son) myself as we can't afford to hire someone. I am quite good at DIY and have a lot of the tools needed already but I have a couple of questions.
It is floating over grass so I will be cementing posts into the ground and I would like to know..
1) if I am digging a hole 300mm by 300mm and the post is 100mm x 100mm won't that leave cement sticking out from the front of the decking? The frame will be attached to the post and then the decking board but I'm not sure that will be 100mm thick so wouldn't the concrete be visible?
2) the decking is going right up to the fence so the holes will have to come in a bit so how do I attach the frame if there is little access as the fence is there and as the post is not right up to the fence do I just put the decking boards hanging over the gap? (That seems wrong) Also the fence is not panels so I can't move it.
If this doesn't make sense I will try and do some drawings to explain what I mean.
Thank you for any help you can provide.
