Inserts
Posted: Wed Sep 15, 2010 12:02 am
by greengrass
For what reason do you need to insert disc's to reduce router cutter hole?
I've been using mine without (its home made) the cutter hole is around 2" across.
Posted: Tue Jul 12, 2011 7:37 pm
by greggy
for safety reasons, ie if you have a gap too big then there is a greater chance of the timber getting snagged in the hole/gap and you then put more force on the wood and get your fingers ripped apart.
the smaller the gap the safer. i would replace your home made one with a proper one that icludes the reducing rings,like trend, incra, kreg etc etc.
Posted: Thu Jul 28, 2011 10:21 am
by greengrass
[quote="greggy"]for safety reasons, ie if you have a gap too big then there is a greater chance of the timber getting snagged in the hole/gap and you then put more force on the wood and get your fingers ripped apart.
the smaller the gap the safer. i would replace your home made one with a proper one that icludes the reducing rings,like trend, incra, kreg etc etc.[/quote]
Yeah thanks for taking the time to reply and I would have bought a manufactured one had I the money to so will be making a top up with a smaller hole for smaller bits I mostly use and keep the large hole one for the large bits on the rare occasion they will be used.
