Issue With Milwaukee M12BDDX Work Light
Posted: Fri May 27, 2016 9:37 am
by beehaus
the small work light above the trigger stays on permanently draining the battery can anyone help.
Re: Issue With Milwaukee M12BDDX Work Light
Posted: Mon May 30, 2016 1:57 am
by cmorales
I have a question.
Is that battery still charging?
If yes, you should go to service center to repair your tool.
If not, you should buy a new battery.
Posted: Mon May 30, 2016 12:22 pm
by beehaus
thank you for the quick reply, I have two batteries that hold full charge. I guess its off to a service counter, unless someone knows how to disconnect the light, as I could do without it.
