What tool is used to unscrew this
Posted: Fri Aug 14, 2020 4:55 pm
by May148706
I've tried a large flat blade and Allen Key and it didn't work! Thanks
Re: What tool is used to unscrew this
Posted: Sat Aug 15, 2020 9:41 pm
Hi may148706,
You need to use a screwdriver large enough to locate in both slots at the same time. If is will not shift you may have to use a punch for the initial release.
Posted: Sun Aug 16, 2020 12:40 pm
by May148706
Thanks a lot ... I thought it needed a special tool!
I can't seem to find a screwdriver with a head larger than 12mm and a small size handle. Any suggestions where to look for these?
Posted: Sun Aug 16, 2020 10:24 pm
Hi may148706
See if you can find a piece of flat steel the right width and use this with an adjustable spanner or grips.
Posted: Sun Aug 16, 2020 10:25 pm
Hi may148706
See if you can find a piece of flat steel the right width and use this with an adjustable spanner or grips. A coin might do the trick.
