Running New Joists Beneath Steel Structure - Can This be Done?
Posted: Mon Jul 21, 2014 9:32 am
Hi, can anyone please answer whether I can run new floor joists beneath my newly installed steel beams. I am currently converting my loft into two bedrooms and installing two x ibeams and a centre flitch plate to accommodate my new floor joists, these joists will run alongside the existing ceiling trusses to both provide a new floor plate but also bolted to my existing to hold up my ceiling. As my new beams are going to support the new trusses, I also need the new trusses to carry through into the eaves and the easiest way I would see is the suspend my new trusses below my steel beams with jha hangers on either side, can this be done?
Thanks in anticipation
