What Order to Construct Stud Partitions in Loft Conversion
Posted: Mon Jan 25, 2016 8:46 pm
I have planning approval for a loft conversion. The loft is going to be made up of four rooms. What I would like to know is what way should I fit the stud partitions. Should I insulate the whole loft and plasterboard it and then instal the stud partitions. Or should I do the stud partitions and then carry out all the insulation plasterboard work. If I did it this way would it cause cold bridging. The insulated plasterboard I have to use on the camb ceiling is 80mm. Any help would be appreaciated.
