Use of Skylight in Low Head Height Loft Conversion for Building Regs
Posted: Tue Feb 13, 2018 1:42 pm
Hello all,
in order to get building regs sign off for a loft conversion, is it permissible to use a skylight in the apex of the roof above the top of the stairs in order to get to the 2m minimum head room height?
Would you then need planning permission?
I've attached an example of the type of skylight that I'm talking about.
thanks
thanks
