Breather membrane required for loft conversion?
Posted: Wed Jul 08, 2020 11:32 am
Hi, thinking about converting my loft. my roof is the original build up and from inside the current loft i can see the rafters, batten and back of the tiles. If i want to convert the loft to a bedroom will i have to strip the whole roof off and relay with a breather membrane in the correct build up? Or is there a way to retain the roof as existing and insulate from inside?
I only intent to put a small dormer on the back so it would be a lot of work if i have to strip the whole roof off!
thanks, JW
thanks, JW
