Advice on Boarding Remainder of Loft
Re: Advice on Boarding Remainder of Loft
by stoneyboy » Tue Apr 20, 2021 10:42 pm
Hi dothehouse
Assuming you do not wish to add extra insulation you will probably find the younger and grooved chipboard sheets from a DIY store the easiest option.
Screw the boards down, do not hammer in nails as this may crack the ceiling below and if you have lathe and plaster ceilings the whole lot may come down.
2/3/4 screws per board is adequate.
by stoneyboy » Tue Apr 20, 2021 10:43 pm
Hi dothehouse
Assuming you do not wish to add extra insulation you will probably find the tongued and grooved chipboard sheets from a DIY store the easiest option.
It is currently Sun Dec 22, 2024 4:14 am
