Lighting Advice Needed for the Ceiling and LED Lights
Zarkopafilis
by Zarkopafilis » Sat Dec 05, 2015 9:34 am
https://www.youtube.com/watch?v=-kQeEdupTmM
This is the room, I also explain where I'm thinking of putting lights.
I want to be able to see a bit while they are on. Also, I am not sure whether I should stick with el wire/led tape/christmas lights due to visibility reasons.
P.S. Extra points for color switching :P
thedoctor
Re: Lighting Advice Needed for the Ceiling and LED Lights
by thedoctor » Tue Dec 22, 2015 11:06 am
Dont understand? Is this to be a permanant installation of just decoration?
Robin2912
by Robin2912 » Tue May 17, 2016 6:29 pm
You could run a strip around the top but you don't have a lot to hide it behind? You could put strip behind a wooden board and it would look quite nice? I put some strip behind gallery wall and it looked good. recommend this for sure http://www.bltdirect.com/single-colour-flexible-high-power-led-strip-light-white-24v-dc
Alternatively you could have some spots scattered around the ceiling? It would give a lot more light than strips? Again Id reccomend these as they are complete units! http://www.bltdirect.com/enlite-8w-warm-white-dimmable-led-fire-rated-ip65-downlight-bezel
It is currently Fri Jan 17, 2025 10:33 pm
