Advise on bond used on garage
Posted: Wed May 27, 2020 3:05 pm
Hi, I have just had the first 2 courses of a garage laid.
The base is very uneven (shoddy work from a previous builder), so the brick layer advised to lay the first 2 course of block flat, to get a good level surface to work with and then build from there.
However when this has been done using stack bond instead of half bond. Is this strong enough to support the remaining courses and a roof?
image to follow.
image to follow.
