I have a situation on having 1 x 6kw solar inverter that has a 10mm twe feeding it as a mains supply. We are fitting a second inverter in parallel to give around 12kw. This would be pushing a 10mm cable & should be upped to 16mm. I do have enough spare 10mm cable to double up. Is this ok to do? & labelled up appropriately as its not dissimilar to a ring main & this is to help with voltage & amperage. .
In this situation i would have 2 x 10mm TWE's from the same 50amp mcb to a local 60amp switch & tails up to each inverter.
I know, not really correct, but trying to save some cash.
