Add a room thermostat to heating system
skybluekev
by skybluekev » Thu Aug 07, 2008 4:15 pm
I was looking at adding a wireless thermostat to my boiler, i was wondering if i need to get a specific thermostat to suit the specific boiler or whether i can just buy any thermostat. Also on the instructions for the boiler it says i need to get a 24v thermostat, is this standard on thermostats because some that i have looked at does not specify the voltage. Thanks, Kev
TheDoctor4
by TheDoctor4 » Fri Aug 08, 2008 9:41 am
Hi Kev
Had you had a look at the DIY project on Central Heating Thermostats: https://www.diydoctor.org.uk/projects/thermostats.htm This may be of some help to you or you may wish to contact Heatmiser for some further advice.
Regards
by ericmark » Sat Aug 09, 2008 9:52 pm
If you need 24 volt control you would normally use something with volt free contacts. Most electronic thermostats will come with volt free contacts.
