Post
by ericmark »
Thu Apr 21, 2016 10:45 pm
I bought two so called "Intelligent" temperature controllers to brew beer with. There is nothing "intelligent" in them. Allowing for the time delay is hard, switch on say as temperature drops to 19°C and switch off at 19.2°C to drop the temperature to compensate for time delay is not really an option. There is only 0.2°C to play with.
Now start with a room at 10°C and warm to 19°C then that's another story. But most motorised valves are on or off, so one would need to alter the mark/space ratio. Sounds good in theroy, but in practice the boiler would switch off when on a space, so when mark time arrives simply no hot water being pumped around.
This is the problem. Each room is independent so to work we need electrical operated TRV's on each radiator connected to a central control unit which in turns tells the boiler when to fire up. As said sensing needs to be close to the radiators, and the only way to ensure whole room even heated is to circulate the air.
The Myson radiator seems to do this, however there is a major problem, the Myson at least the one I have does not restrict water flow, all it does is switch fan off and on. Hot water arriving back at the boiler will turn boiler off with condensation type, so only way is to pipe in series not parallel, this is the method used with large buildings.
So all electronic control is no longer required. Time switch starts boiler, as the water get hot the Myson switches on its fan until the room is at set temperature when fan switches off, when no Myson's are running then hot water returns to boiler who's anti-cyclic software varies the off time before it re-tries. Yes it works. However a Myson in the living room is one thing, having the fan kick in with a bedroom is not really what I want.
But it only really helps heating up from cold, once warm no real advantage. In real terms the Honeywell Evohome is about the best commercial control system after the Myson radiator. To make your own TRV is not really cost effective. It is the Wifi controller which one could possible use a raspberry pi to replace. So £181 for the Evohome controller. You need to find out how to control the TRV with the raspberry pi and get a touch screen to control it with plus all the smart phone software. Not saying it can't be done. But really more than I would want to tattle.
There are other systems made like the nest and hive, however these are really for a hot air system not a water system. With hot air circulation all rooms are the same temperature. So all you need is one thermostat for whole house. But with water systems each room is individually controlled so the nest and hive don't work. Yes they and switch heating on and off remotely but they can't control the temperature of all rooms. They can only control one room. And most people do not live in one room houses.
