Advice on Sewage System Under Slab Foundation
devmanoj
by devmanoj » Wed Apr 24, 2019 2:18 pm
What are the pros and cons of having the sewer pipework under the slab foundation? On our existing renovation work, the builder has changed the previously external sewer to an internal under the slab foundation one that runs along through living room and out to the garden. With tile flooring and underfloor heating, do you reckon it will be a hassle in case of possible future leaks/blockages? All the upstairs and downstairs bathrooms, utility and kitchen sink drainage will be connect to this pipework that runs under the living room slab foundation.
Any advice is much appreciated.
Regards,
Manoj
B4Less
Location: 3rd Floor, 207 Regent Street, London, W1B 3HH
Re: Advice on Sewage System Under Slab Foundation
by B4Less » Mon Apr 29, 2019 4:47 pm
Yes I would advise not to do this. It is always best to avoid any sewer piping to run under concrete flooring or footpaths as much as possible.
The last thing you want is a blocked pipe under your sitting room floor and no way to clear it. An AJ or manhole will not suffice as sometimes you do have to get down to a pipe to unblock it.
Although running the pipe under the floor is the quickest and cheapest way of doing it but its better to take it out of the house and run it around the perimeter.
Regards
It is currently Fri Sep 18, 2026 11:25 am
