We've had occasional problems with what we think is penetrating damp.
This probably isn't a DIY job but I'd appreciate any views/opinions on what might need to be done.
The semi was built around 1969 as part of an MOD estate.
Roof has had new felt, batten and ridge/verge a few years ago.
The damp issue only happens occasionally when persistent heavy rain is driven from the southeast/northeast.
Some years we don't notice any problems inside at all.
Over the last few weeks its been non stop heavy rain from the southeast and the results can be seen in the photo's, with wet patches at various points on the wall, a large wet patch in the centre of the wall at the bottom, and a wet patch near the back door from floor to ceiling.
Pretty sure the drainpipes aren't overflowing, I looked out the other night during a heavy downpour and couldn't see anything overflowing from the top.
That said (see photo), it looks like the drain underground has collapsed, or at least the ground is sunk, but that's a separate issue and has been like it for quite a few years (survey and groundworks no doubt needed).
The most pressing issue is definitely the wet spots appearing inside.
When we first moved in around 2011 and stripped the wallpaper and attempted to paint the wall with a roller, chunks of plaster were coming off on the roller, no doubt as a result of earlier penetrating damp, and we've since had it replastered, although that will probably fall off now as well!
Thanks.
https://drive.google.com/drive/folders/ ... sp=sharing
