We have an open vented central heating system. I regularly have to bleed the radiators in order to remove air bubbles that make quite a noise as they travel round the system. Just as I think I have got it all out the noise starts again and I have to bleed again. The header tank in the loft is approx half full and the open vent is clear of the surface. It almost sounds as though the pump is drawing in the air, the only place I can think it comes from is the open vent. I have read on a couple of sites that the pump/vent/boiler order is important but the correct order is not always clear. How can I diagnose if the air is coming in through the open vent and does anyone have any suggestions about how to cure it? Would some kind of additive help? (Also what is the function of the open vent as the system is open to the header tank anyway?)
Cheers.
