i have another hot water problem on a baxi combi 80e
the problem is that when a mixer shower is used that is on the combi boiler the boiler keeps turning on and off. i have noticed that the diverter valve keeps going in and out, thus causing the boiler to turn on and off. This does not happen if a tap is turned on as the boiler will stay fired up. i have noticed that if a tap is turned only slightly on the boiler will not fire up untill there is quite a lot of flow rate. i think it might need a new diaphragm but was just wondering why would the diverter valve keep moving in and out while the shower is on. could it be from pressure backing up from the shower head or do i need to look at another thing
cheers
paul
