Back Boiler Pump Location
Gor84
Post by Gor84 » Thu Jun 13, 2019 8:10 pm
I recently moved into a house and have done a bit of home improvements. But now the oil boiler is malfunctioning and we are switching to gas.
Long story short I need to find the pump for the back boiler. It never worked and only heated water and no radiators but there is a switch on the fireplace wall.
All wires run up from it. I lifted a bit of my NEW carpet in the room above and found the wires were disconnected. From what I can see there looks to be a join in the pipes about where the wires were cut and a small piece of timber on either rafter.
There are only two pipes running down to the fire place. Is it safe to assume that the pump has been taken out?
I cant lift the floor at the fire now but i did have a hoke around when we were putting the floor down there and dont think it is on one side of the fireplace. I didnt check the side where the pipes are not.
Re: Back Boiler Pump Location
Post by htg engineer » Fri Jun 21, 2019 8:16 pm
If there's no radiators, there's probably no pump. The water side will be a gravity setup.
