I updated this post to try and make it a little clearer. Unfortunately my system doesn't conform to any of the Honeywell 'sundial' plans, and I can't find any schematic that has the same layout (it isn't gravity fed)
I am struggling to sort out a problem with a single radiator not getting hot. All other radiators in the house work fine and get up to temperature pretty uniformly.
Taking off the rad flushing the rad, as well as the whole system, hasn't helped.
In doing so, I also checked feed/return both had free running water so I don't believe there is any blockage.
I've now closed all radiators except the bad one and it still isn't getting warm.
My system is an old one based on Randall 102 programmer, with a single 2-port valve to control the central heating - so I can have hot water only, or hot water+heating, no independent heating. So I suspect that the water is short-circuiting the radiators by going through the hot water loop. The cylinder has a lock shield valve next to it and I believe this is to control how much water can short circuit the heating loop, and I am tempted to try closing this valve. However, I am concerned that I may cause damage to my system by over-pressurising it when I only want hot water.
I would appreciate any advice.
Thanks in advance.
