Bathroom fan connection in loft using vent tile
Teamperchpan1982
by Teamperchpan1982 » Tue Feb 22, 2022 11:14 pm
Hi, I have had a mould problem and found my bathroom fan was just covered over with loft insulation. Have opened it up but obvious all steam is now going into the attic. In the attic is an old outlet metal tube leading to open tile on the roof to let fumes from old gas fire( this has been removed so a there is left is the metal tub from the roof which extends 1 metre into the attic at which point it has been disconnected). My question is could you attach the tube from the extractor fan to the end of the metal tube for the steam to go out? I realise that I would probably need a powerful fan as the distance would be approx 4 metres with a bend but would it work or is it allowed ?
Peter
Re: Bathroom fan connection in loft using vent tile
by stoneyboy » Wed Feb 23, 2022 11:02 pm
Hi teamperchpan1982,
Yes you can do this but make sure you make provision for dealing with condensation that will inevitably form in the ducting.
Teamperchpan1982
by Teamperchpan1982 » Thu Feb 24, 2022 8:59 am
Would this involvement wrapping insulation around all the piping ? Thanks
by stoneyboy » Thu Feb 24, 2022 9:37 pm
Wrapping the pipe with insulation is unlikely to gain anything. You need to have the pipe coming up from the extractor and immediately going down again - so the pipe is like a giant S on its side. Condensation will form in the pipe collecting at the lowest point and hopefully this will evaporate off out the roof vent between on periods. If it doesn’t you will have to fit a drain at the lowest point or fit a trickle vent type fan.
It is currently Thu Jan 09, 2025 3:36 am
